Xillinx Vhdl: could not get function return to output port
Hi , im trying to use function to get the return value for output port but i get this error:
ERROR:Pack:2309 - Too many bonded comps of type "IOB" found to fit this device.
ERROR:Pack:18 - The design is too large for the given device and package.
function weight
			(x1,x2,x3 : integer)
			return integer is
	begin
		return x1 + 2*x2 + x3;
calc:process
		begin
			Eh := weight(pixel1,pixel2,pixel3);
			output <= Eh;
		end process;
 how to solve this?
The datasheet/userguide for your dev board will tell you the pinout for the FPGA device. These need to be assigned in your VIvado project.
For top level ports, I recommend you do not use integers.
This is unlikely to be a problem with the function. An integer is 32 bits. does "output" go to a pin? do you have 32 pins free to export all the bits?
Im not sure if its because integer, when i change
output <= Eh;
to
output <= pixel1;
it fixed the error where pixel1 is integer too.
here is my entity
entity function_test is
    Port ( pixel1 : in  integer;
           pixel2 : in  integer;
           pixel3 : in  integer;
           output : out  integer);
end function_test;
anyway i just recently learning using vhdl how do you check available pins?
thx for the solution it works. i change the return value from integer to 9 bit vector as well as the output type
