tchin123
Voyager
Voyager
ZCU106 board with "IOSTANDARD error" during Implementation
I'm using the Xilinx ZCU106 development board and during implementation I received a error message as shown below.
I match the same IOSTANDARD in my xdc file as what Xilinx recommend. for the I2C1_SDA_and I2C1_SCL signals in my design.
[DRC BIVB-1] Bank IO standard Support: Bank 65 has incompatible IO(s) because: The LVCMOS12 I/O standard does not support a drive strength of 12. Move the following ports or change their properties:
i2c_scl
But The xdc that comes with this board also calls out the same IO STANDARD for LVCMOS12 as shown:
##### ZCU106 Rev1.0 XDC 02/10/2018
set_property PACKAGE_PIN AL21 [get_ports "PL_I2C1_SDA_LS"] ;# Bank 65 VCCO - VCC1V2 - IO_L7N_T1L_N1_QBC_AD13N_65
set_property IOSTANDARD LVCMOS12 [get_ports "PL_I2C1_SDA_LS"] ;# Bank 65 VCCO - VCC1V2 - IO_L7N_T1L_N1_QBC_AD13N_65
set_property PACKAGE_PIN AH19 [get_ports "PL_I2C1_SCL_LS"] ;# Bank 65 VCCO - VCC1V2 - IO_T1U_N12_65
set_property IOSTANDARD LVCMOS12 [get_ports "PL_I2C1_SCL_LS"] ;# Bank 65 VCCO - VCC1V2 - IO_T1U_N12_65
Please help.
hpbhat
I see that error is not for LVCMOS12, instead error message says drive strength of 12mA is not supported.
I think Bank 65 is HP bank & in HP bank, drive strength 12mA is not supported for IO standard LVCMOS12.
Changes the Drive strength to the particular pin.
Please refer to below link.
UltraScale Architecture SelectIO Resources User Guide (xilinx.com)
page 66
hpbhat
page 66
