ZYBO Constraint error in XDC file
I am using push buttons, slide buttons and leds to test a program on ZYBO.
I am using the master XDC file but implementation fails. The IO Standards are also right. The screen shot of implementation failed can be seen in attachment.
Re: ZYBO Constraint error in XDC file
Hi @joniengr081.
The UCIO-1 DRC is indicating that a LOC or PACKAGE_PIN constraint is also needed. The image shows that the IOSTANDANDARD is set, but to remove the UCIO-1 error a LOC constraint is also necessary. For example.
set_property LOC A9 [get_ports rgb_2_0[0]]
or
set_property PACKAGE_PIN A9 [get_ports rgb_2_0[0]]
Hi @joniengr081.
or
