about the implementation duplication in virtex7
Hi, there
Now, I am working virtex-7-2000T. Basically, there are 4 NAND PHY, which support DDR interface. So, the timing requirement is a little bit tight. So, after we setup the correct constrains in the XDC, the timing is closed on 0326 implementation. But, on 0328, we change the RTL, not NAND PHY design, VIVADO report timing failure, around -3ns. But, 0326 and 0328 have exact same design for NAND PHY. The following is the 4 sub-module with DDR interface.
u_core_top/u_pd_top/u_ncb_top/ndphy_ch_inst[0].u_ndphy_ch_top_inst_ho.u_ndphy_ch_top_ho
u_core_top/u_pd_top/u_ncb_top/ndphy_ch_inst[1].u_ndphy_ch_top_inst.u_ndphy_ch_top
u_core_top/u_pd_top/u_ncb_top/ndphy_ch_inst[2].u_ndphy_ch_top_inst.u_ndphy_ch_top
u_core_top/u_pd_top/u_ncb_top/ndphy_ch_inst[3].u_ndphy_ch_top_inst_ho.u_ndphy_ch_top_ho
I am thinking whether there is any way for me to copy the 0326 NAND_PHY to 0328 design directly, including loc, FF, route path, etc.  I try floorplan before, but timing is worse. I hope that we can get the consistent implementation when NAND PHY is exactly same.
It is highly appreciated it if someone can solve my problem. thanks
Ping Chen
2018.3.29
Re: about the implementation duplication in virtex7
Hi @chenpingx. There are two reuse flows that I can suggest that might help. The first is the incremental compile flow. This is more useful with designs smaller changes between design iterations. With this flow, a previous reference checkpoint will be used by the implementation tools to complete the placement and routing of the new version. The Implementation Guide has more on this on page 94:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug904-vivado-implementation.pdf
There is also Hierarchical Design flows. There are several levels of reuse, but you could physically separate areas that you want to keep the same placement and routing. You might not see the same QOR though, as the physical separation will limit the placement and routing options. The below Hierarchical Design Guide has more information.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug905-vivado-hierarchical-design.pdf
thanks for reply. I will try #2 for hierarchy design.
For incremental compile, I tried it before, even worse.
Ping Chen
2018.4.6
@chenpingx,
Did you try the HD flow?
Also if you can share the design which is showing bad results with incremental compilation flow then I can forward it to Factory.
--Syed
thanks for your information.
update the status. After applying the LOC constrains the IDDR/ODDR, it is quite consistent to get the good implementation result, just -0.2 ns setup timing violation. So, i think it is OK now.
For HD, i don't try it.
Ping Chen
2018.4.10
@chenpingx,
Thanks for the update. For closing on timing, i would request you to post the new query in timing board.
Please close this thread by marking the above post of @marcb as "Accept as Solution"
--Syed
