Visitor cocies
apply the following bitgen swith "-g UnconstrainedPins:Allow"
 Hallo Everyone,
I got an error by “Generate Programming File”. The error number is “Bitgen:342”.  I don’t want to assign the location for every Pin. I have tried the “bitgen -g UncontrainedPins:Allow” in the command line. But it doesn’t work. It is very hard for me, because I have never really worked with command line.
Thanks for all the help
Re: apply the following bitgen swith "-g UnconstrainedPins:Allow"
Go to Generate Programing File & right click & check the process properties.
In general options you will find other bitgen command line option.
write the command there
Hi Vintu,
It is recommended to do that. If you want to overcome the error message without specifying the LOCs as said before you can specify the switch  -g UnconstrainedPins:Allow in More options field of Bitstream settings and re-running bitgen.
Check the attachment.
thanks
Use this command in Tcl console:
set_property BITSTREAM.General.UnconstrainedPins {Allow} [current_design]
Visitor cocies
I actually use ISE Navigator. Can I change it in Navigator.
Is this Vivado?
I tried what you suggested but I get the following error (see attached)
How to assign this option in the Vivado?
I think I solved it as follows:
I created a .tcl file with :
set_property SEVERITY {Warning} [get_drc_checks NSTD-1]
set_property SEVERITY {Warning} [get_drc_checks UCIO-1]
then in the Bitstream settings, I pointed to this file in the first item called tcl.pre
