Visitor timostehmann
attribute IOB "FORCE" on bi-directional pins
I haven't tried IOB packing before, but I have some timing issues with an external memory bus. I am using Spartan-6. The IOB packing works for pure output pins. However, I have a bidrectional data bust. The output data (including tri-state 'Z') is clocked out onto the DATA_BUS. However, when I try to read data from DATA_BUS (e.g. data_bus_snapshot <= DATA_BUS) it generates Pack:1560 error. Ok, it makes sense, because it looks like the output of the packed FF is being used back inside the FPGA and that prevents moving the FF into the IOB. However, how else can I get hold of the data on the DATA_BUS?
Sorry, in advance for a probably stupid question.
Re: attribute IOB "FORCE" on bi-directional pins
Hi @timostehmann
Rather than tapping the data at ouput of register which is getting packed in to IOB, You can tap the data at the register input. If possible you can add additional register on this path so that you loop back registered output.
Deepika.
Hi @timostehmann
Deepika.
Thank you vemulad! That makes sense.
