can't generate Bitstream : vivado 2013.4
hello,
i have the same problem ( windows 7 64 bits, vivado 2013.4 )
i restart many time , vivado, i update a new license , but the same problem repeat again and again,
failed in genarate Bitstream ( the step before it, go without any problem ), just i need the bitstream, to add it when i lunch the SDK ?
anyone have idea
thank you
My blog : www.xilinx-video.blogspot.com
Re: can't generate Bitstream : vivado 2013.4
hello
it's work, the generation of BitStream is done with success
when i repeat the project, i found that i forget some output name, ( i pass without modification), also i found that there is some instruction in the *.v file, i didn't instanciate the module into the System_wrapper.v file
and about the specification of the setting ( Led output ), there is no wrang, when i turn to 3.3 v as a voltage ( isn't the source of the error )
the number of the led, it's shown as more then 8 ( on the boad there is 8 leds), because of the forget of the instanciation (  Output Led [7:0] LEDS;  ( if i add this instruction in the *.v file ), in tge port i/o planing , we will fount this number.
so i think the problem isn't from the license or otherthing, just it's a forget of some instructions
thank you again for your support, and i will marque this post as a solution
Can you please attach your license file?
Thanks,Vijay
What are the errors you face during bitstream generation?
Check the log and copy the error messages here.
Deepika.
Deepika.
The bwelow user guides can guide you well
http://www.xilinx.com/support/documentation/sw_manuals_j/xilinx2013_4/ug936-vivado-tutorial-programming-debugging.pdf
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/ug973-vivado-release-notes-install-license.pdf
Do you still see have the bitstream generation issue?
Please share the log so that we can review it and suggest you.
Achutha
hello,
yes, i still have a problem with generate Bitstream, ( the implementation is ok ), i try to update the license, but vivado ask me again to make sure about the implementation license
check here the log message : http://pastebin.com/njXQFSi5
thank you
hello again,
i think , the problem isn't come from the license, but with a violence use of a pin I/o an also power stting for board
check here
Have you defined all the IO standard of the ports. If not then please define the IO standards.
The error message is to notify customers that they need to set IOSTANDARD and LOCs in order to protect devices from accidental damage that could be caused by the tools randomly choosing a pin location or IOSTANDARD without knowledge of the board voltage or connections.
For example:
If a pin is tied to ground on a board and ISE Design Suite chooses this pin as an output that is driving high, this causes contention.
If you have a termination scheme on the board for a pin that is the HSTL or SSTL recommended termination and ISE Design Suite chooses LVCMOS18 (default), the signal integrity of the signal will be less than optimal.
The default I/O standard for the 7 Series is LVCMOS18 for single-ended signals for all banks, the default I/O standard was LVCMOS25 in previous architectures.
As the message indicates, the error can be down graded to a warning by using the following constraints
set_property SEVERITY {Warning} [get_drc_checks NSTD-1]
set_property SEVERITY {Warning} [get_drc_checks UCIO-1]
These cannot be set in the XDC file. It is recommended to place the command in a script.tcl file and source this Tcl file inside the project or the larger scripting flow.
Harry
hello,
throw to ZedBoard documentation : check it here  ,
so i fix it,
i will see later, if it's ok or no
hello
thank you for the response, but throw the message, it's not recommanded !
and i can't found the "Standard" value
The error message doesn't say that the IOSTANDARD that you are targeting is invalid, it states that you are using the default IOSTANDARD. If your design requires to use default IOSTANDARD then use the XDC constraints given by @harry.
same problem
this is the log message: http://pastebin.com/mv16JHHf
thank  you
Hi gma-87
can you open the implemented design and verify that these IO still have these I/O standard constraints set?
If not present anymore, can you verify the log-file and look for messages regarding these constraints not being applied?
Can you check your target XDC file and verify if these IOSTANDARD constraints are present?
Best regards
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
Can you please be specific on what you did? Did you
1. Define the IOSTANDARD or LOC of the unconstrained pins
or
2. Included the following commands in xdc
yes, i include those instruction, i run again, but the same message again :(
any way, i re-create the project, maybe i have a problem in the begin, ( even am sure that all is ok, because all step, finish by success
Please source the attached tcl file to tcl.pre in the Bitstream settings and see if the error is resolved.
hello
