04-07-2021 04:55 PM
Hi all,
I want to fix this critical warning.
[Timing 38-194] Unsupported spread-spectrum parallel clocking configuration found between CLK66M and CLK_OUT1_CLKGEN_20M3. Timing analysis will be inaccurate!
Resolution: If the logic between the 2 clock domains needs to be timed, then the spread-spectrum clocking configuration should be removed from both CMBs.
If the logic between the 2 clock domains does not need to be timed, then an exclusive clock group can be defined between the 2 clocks domains:
set_clock_groups -group [get_clocks source_clock_domain] -group [get_clocks destination_clock_domain] -logically_exclusive
These nets CLK66M and CLK_OUT1_CLKGEN_20M3, CLK66M exists on the XDC file, but strangely CLK_OUT1_CLKGEN_20M3 does not exist.
Of course, if add constrain net CLK_OUT1_CLKGEN_20M3, a No valid pbjects error will occur.
So far, I know the details of Net CLK_OUT1_CLKGEN_20M3 are as follows.
[U_CLKGEN/M_CLKGEN_20M3/inst/CLK_OUT1_CLKGEN_20M3]
Why does Net CLK_OUT1_CLKGEN_20M3 get a critical warning? How can I resolve this critical warning?
Thank you and regards.
04-07-2021 07:20 PM
Have you tried to separate the clocks with set_clock_groups command suggested in the CW and handle the CDC path with logical method?
Ex: set_clock_groups -group [get_clocks CLK66M ] -group [get_clocks -of [get_pins U_CLKGEN/M_CLKGEN_20M3/inst/CLK_OUT1_CLKGEN_20M3]] -logically_exclusive
04-07-2021 07:37 PM
Dear hongh
Thank you very much for your quick responce.
I tryed that method.
However, as I wrote in the question, "No valid objects" occur at the time of implementation.
This "No valid objects" is occurring for "CLK_OUT1_CLKGEN_20M3".
Thank you for your continued support.
04-07-2021 07:49 PM
What's the command your are using? "get_clocks CLK_OUT1_CLKGEN_20M3" or "get_nets CLK_OUT1_CLKGEN_20M3" ?
Have you tried the command I provided?
04-07-2021 09:54 PM
Dear hongh
I tryed two constraint methods.
First below,
create_clock -period 50.000 -name CO1_20M -waveform {0.000 25.000} -add [get_nets U_CLKGEN/M_CLKGEN_20M3/inst/CLK_OUT1_CLKGEN_20M3]
set_clock_groups -group [get_clocks CLK66M] -group [get_clocks CO1_20M] -logically_exclusive
Next below,
set_false_path -from [get_clocks CLK66M] -to [get_pins U_CLKGEN/M_CLKGEN_20M3/inst/CLK_OUT1_CLKGEN_20M3]
However, in both cases, No valid objects have occurred.
See the attached file for details.
regards
04-07-2021 10:11 PM
added attachfile
04-07-2021 10:13 PM
Could you provide your synthesized dcp?
04-07-2021 10:22 PM
Is the top DCP file in the hierarchy okay?
04-07-2021 10:36 PM
04-07-2021 11:11 PM
Hi, @suzuki-run ,
Please upload the complete dcp with Ezmove link sent to you.
For MMCM/PLL in the design, please create clock on the input pin of MMCM/PLL and the tool will derive output clock automatically.
04-07-2021 11:15 PM
Hi @suzuki-run
Did you try to disable spread spectrum on CLK66M ?
If no, would you try it ?
As you may know, EDA tool can't calculate proper waveform during STA stage.
Hope this helps.
Best regards,
04-07-2021 11:23 PM
I know that, But I absolutery need spread spectrum.
I'm sorry to have taken the trouble.
Thank you
04-08-2021 12:01 AM - edited 04-08-2021 12:09 AM
Ex:
set_clock_groups -group [get_clocks CLK66M] -group [get_clocks -of [get_pins U_CLKGEN/M_CLKGEN_20M3/inst/CLK_OUT1]] -logically_exclusive
04-11-2021 05:47 PM
Dear hongh,
I will try to use report clock interaction.
Thank you
