Voyager
Voyager
design not working as expected after Floorplan ?
Hi Friends,
I have many timing violations in my design that too on the intra paths, even though it worked for me. to reduce the timing i did Floor plan and timing also improved a lot almost 1000 nets violations got resolved, but my design is not working. Is it possible ?
May i know what could be the reasons for this?
NOTE: Any help or suggestions are highly appreciated.
Thank You
S Sampath
-Sampath
回复: design not working as expected after Floorplan ?
Hi @ssampath
What's the meaning of "my design is not working"? I think a good way is debug your design . There are many IPs support such as ILA,VIO... You can check every signals in your design .
And you also set correct timing contraints, you can refer to it  . The less timing constraints in your design , the better it works.
Hope it can help you.
Scholar dpaul24
Re: design not working as expected after Floorplan ?
@ssampath,
As mentioned in the above post, you must be specific to get help.
Did your design pass functional verification? Do you have a test-bench to verify your design?
It was working by chance at room-temp, you cannot be sure with such a design.
FPGA enthusiast!
All PMs will be ignored
Voyager
Voyager
Hi @yangc ,
My design having processor, am unable to access the processor with JTAG after floor plan. Before Floor plan with Timing violations am able to access processor.
-Sampath
Hi @ssampath ,
I don't confirm that floor plan result in the problem. How about copy the xdc file to other folder and delete constraints?Do you reproduce it?
Voyager
Voyager
Hi @yangc ,
old xdc i keep it same but after adding the Floor plan i saved as new constraints file with fp.xdc.
-Sampath
