Observer urmilagavale
display image on monitor using spartan3E
I have stored pixels of image on bram using .coe file. now i want to display image on monitor but i am not getting how to do exactly that. i have read some tutorials on vga controller. but my problem is that after writing a code for vga controller, where to assign my bram output which are the pixels of image ,to show image on monitor.Even i am not getting how to write ucf file. i need a guidence.
Re: display image on monitor using spartan3E
Hi Urmila,
1. VGA Controller is basically a video timing generator which generates video timing parameters
  a. Pixel clock
  b. Hsync
  c. Vsync
  e. Video enable
  f.  Pixel data
 2.Since your image is stored in the BRAM,you need to write BRAM read control logic and
    you should synchronize the read data with the timing generated by the VGA Controller(pixel data and video enable should be     alligned).
 3. You could use the video enable generated by the VGA controller as read enable for BRAM to read the pixel data .
     (here you may need to  insert delays to video parameters so as to make the read data from BRAM in sync with the video             timing parameters before driving the display)..
Hope this helps.
Aneesh.
ok i will try to write a code. thank you for reply.
this seems good link
http://www.eetimes.com/document.asp?doc_id=1274613
Thanks and Regards
Balkrishan
I have written the following code. In which i am reading pixels stored in bram. but can you tell whether i am right or not?
-- Company:
-- Engineer:
-- Create Date:    13:59:44 05/27/2014
-- Design Name:
-- Module Name:    maincode - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity maincode is
port(
clk   : in std_logic;
rst   : in std_logic;
hs_out: out std_logic;
vs_out: out std_logic;
red   : out std_logic_vector(1 downto 0);
green : out std_logic_vector(1 downto 0);
blue  : out std_logic_vector(1 downto 0);
Address : out STD_LOGIC_VECTOR(9 DOWNTO 0)
end maincode;
architecture Behavioral of maincode is
    signal wea :  STD_LOGIC_VECTOR(0 DOWNTO 0):="0";
    signal addra :  STD_LOGIC_VECTOR(9 DOWNTO 0):="0000000000";
    signal dina :  STD_LOGIC_VECTOR(7 DOWNTO 0):="00000000";
    signal douta :  STD_LOGIC_VECTOR(7 DOWNTO 0):="00000000";
    signal pclk:  STD_LOGIC;
    signal pixel_data: std_logic_vector(7 downto 0);
    signal hcounter : integer range 0 to 800;
    signal vcounter : integer range 0 to 521;
COMPONENT input_image    ----component(bram) declaration.
  PORT (
    clka : IN STD_LOGIC;
    wea : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
    addra : IN STD_LOGIC_VECTOR(9 DOWNTO 0);
    dina : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
    douta : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END COMPONENT;
begin
process (clk)
begin
  if clk'event and clk='1' then
    if (pclk = '0') then
      pclk <= '1';
    else
      pclk <= '0';
    end if;
  end if;
end process;
your_instance_name : input_image   ---bram instantiation
  PORT MAP (
    clka => clk,
    wea => wea,
    addra => addra,
    dina => dina,
    douta => douta  --pixel out from bram
add_inc: Process(pclk,rst)    --- process to increment address of bram in which pixels are stored.
 begin
 if rst='1' then
 addra<= (others=>'0');
 elsif pclk ='1' and pclk'event then
 addra <=STD_LOGIC_VECTOR((addra)+1);
 Address<=addra;
 end if;
 end process;
 pixel_data <= douta;                         -- bram out pixels are assigned to pixel_data
p2: process (pclk, hcounter, vcounter)
variable x: integer range 0 to 639;
variable y: integer range 0 to 479;
begin
-- hcounter counts from 0 to 799
-- vcounter counts from 0 to 520
-- x coordinate: 0 - 639 (x = hcounter - 144, i.e., hcounter -Tpw-Tbp)
-- y coordinate: 0 - 479 (y = vcounter - 31, i.e., vcounter-Tpw-Tbp)
x := hcounter - 144;
y := vcounter - 31;
if pclk'event and pclk = '1' then
-- To draw a pixel in (x0, y0), simply test if the ray trace to it
-- and set its color to any value between 1 to 7. The following example simply sets
-- the whole display area to a single-color wash, which is changed every one
-- second.
if x < 640 and y < 480 then
red <= pixel_data(1 downto 0);
green <= pixel_data(3 downto 2);
blue <= pixel_data(5 downto 4);
else
-- if not traced, set it to "black" color
red <= "00";
green <= "00";
blue <= "00";
end if;
-- Pulse width: Tpw = 96 cycles @ 25 MHz
-- Back porch: Tbp = 48 cycles
-- Display time: Tdisp = 640 cycles
-- Front porch: Tfp = 16 cycles
-- Sync pulse time (total cycles) Ts = 800 cycles
if hcounter > 0 and hcounter < 97 then
hs_out <= '0';
else
hs_out <= '1';
end if;
-- Pulse width: Tpw = 1600 cycles (2 lines) @ 25 MHz
-- Back porch: Tbp = 23200 cycles (29 lines)
-- Display time: Tdisp = 38400 cycles (480 lines)
-- Front porch: Tfp = 8000 cycles (10 lines)
-- Sync pulse time (total cycles) Ts = 416800 cycles (521 lines)
if vcounter > 0 and vcounter < 3 then
vs_out <= '0';
else
vs_out <= '1';
end if;
-- horizontal counts from 0 to 799
hcounter <= hcounter+1;
if hcounter = 800 then
vcounter <= vcounter+1;
hcounter <= 0;
end if;
-- vertical counts from 0 to 519
if vcounter = 521 then
vcounter <= 0;
end if;
end if;
end process;
end Behavioral;
thank you i tried to write a code. can check it whether its correct or not?
Historian
Historian
Why haven't you simulated your code? That's a lot more effective than throwing it up on an Internet forum and asking others to verify it for you.
Sorry, but i have simulated it and i got the results. But i am not getting whether it is write or not.
pixel_data in my code is bram output.
And by following assignment i am getting what i have written in assignment.
but my question is now that whether i am going in right direction to display image stored in bram?
now i have flashed my program on spartan 3E kit and connect laptop's monitor to kit via vga port. but my first problem is my laptop does not recognize connected device. i have vga driver installed already ,then also the same problem. where is the problem?plz guide
Can you please monitor HS and VS on scope . You can just generate some test pattern in FPGA and see if you can see something on scope. Assign "FF" monitor should look like white in this case.
Thanks and Regards
Balkrishan
to monitor HS and VS on scope i have to use SMA connector? but how my problem of not detecting device will resolved then?
It seems you have issue with device configuration. Check the cable connection. what is the error you are getting while target device configuration.
Is any other code working on your design . check with small code like counter .
VGA driver not needed here.
First you need to make sure you FPGA working condition and you can detect and configure correctly later we will see your specific code
Thanks and Regards
Balkrishan
Yes sir, other codes like counter,AND gate are working on fpga. I m getting output on board.
I think the problem is with vga port and cable connection. i will check it again tommorow.
But i want to ask is it possible to display image on laptop's monitor through vga port. I have vga driver installed with my laptop,but  then also when i connect vga cable, i got a message that device not recognize. What can be the problem,i am not understanding.
It seems you don't have issue with FPGA configuration. I am not which laptop you and I am not sure whether it possible to input VGA input in Laptop,.
I think you can just use normal desktop PC monitor and configure your monitor for VGA .
The other test i had asked you in the morning . you just need to probe the HS and VS on CRO.
Thanks and Regards
Balkrishan
Check this link
http://www.javiervalcarce.eu/wiki/VGA_Video_Signal_Format_and_Timing_Specifications
Thanks and Regards
Balkrishan
Sorry but what do you mean by probe HS and VS on CRO. You mean i have to check HS(i.e hsync) and VS(vsync) on CRO using SMA connector?
I meant horizontal sync(HS) and vertical sync(VS). Probe pin 13 and 14
Thanks and Regards
Balkrishan
ok..thank you.i will check it tomorrow in college.
Historian
Historian
Why would you connect your laptop's VGA output to the Spartan 3E kit's VGA output?
For now i believe you must try on some other monitor. You must have spare monitor on your college.
I think probing VGA on SCOPE will definitely help .
In case if you are not getting any output from FPGA board . You must need to check ucf file and your code.
Thanks and Regards
Balkrishan
I think i have to check my code again as there is no output even if i changed the monitor.
please check the ucf first. You need verify ucf with board ucf.
Have you checked signals on scope.
Thanks and Regards
Balkrishan
I am not familiar to FPGA this may be very basic but I understand that you have the stream of data transfering from the VGA port to the PC but its all zeros and ones how do you transfer those numbers to an image on the PC?
thanks
