fix routing from pin to reg RTSTAT-5 error
I'd like to fix route from pin through a LUT and then to a reg, in the device window I chose the net and fix routing the nets.
But when I generate bit file there is error.
@yearnwaipo,
Are you seeing any error without using FIXED_ROUTE property? Check the following Answer Record to debug the issue:
https://www.xilinx.com/support/answers/54795.html
https://www.xilinx.com/support/answers/53854.html
--Syed
@syedz, when I chose the net in device window and fix routing the net, there is an error.
"Error: [Vivado 12-1406] Cannot mark the 'site' location of instances fixed, Could not find a valid bel"
I have read the "https://www.xilinx.com/support/answers/54795.html", but it seems can't resolve my problem.
I first unroute and then route the net,  and then I check the DRC, the error still exist.
If I comment the fixed_route then I can generate bit file successfully, but that not what I wish to do.
Hi @yearnwaipo
Did you get the values using get_property ROUTE command on routed design?
Which version of vivado are you using? Can you share the _routed.dcp file?
Deepika.
@vemulad, I use get_property ROUTE, the result is a little different, I don't know why.
The first line is my constraint, the second line is the result of get_property ROUTE [get_nets ...]
I have revised all my constrs the same as the result of get_property ROUTE [get_nets ...], and there is not any change for the error.
What's more, I've add "dont_touch" in the verilog code for the wires and XOR, and it seems no difference.
I use vivado 2015.2 version.
Thank you very much!
@yearnwaipo,
Not sure how you have applied the property as when I route the design after unset IS_ROUTE_FIXED property and later reapplied IS_ROUTE_FIXED all the nets are successfully routed. I used Vivado 2017.1.
I was also able to generate the bitstream.
--Syed
@Sye, I use the 2017.1, the error still exist.
Sorry, the last .dcp is the one which I deleted all the FIXED_ROUTE constrs, and it's right.
This routed.dcp attachment is the one with the problem.
I'm very grateful to you for your help.
@vemulad, @syedz,  could you give me some suggestion? Thank you very much!
