Visitor greglac
force_replication_on_nets fails due to DONT_TOUCH
I'm using vivado 2017.1 on a rather large design for an ultrascale+ xcvu9p device. The majority of the design is implemented in IP integrator and uses a combination of custom user packed IPs and xilinx IPs.
I am having difficulty closing the timing on a synchronous reset with a very high fan out, especially since it crosses SLRs and is on a fairly fast clock domain. In an attempt to fix this I have used phys_opt_design -force_replication_on_nets after placement. However the command doesn't perform any replication since it appears several of the xilinx IPs  connected to the reset have the DONT_TOUCH attribute set to TRUE. To sanity check that I am not using the command improperly I have used it at the same point in the flow on a different net successfully.
I am under the impression that I should still be able to replicate the driver and split the global net since the driver cell does not have DONT_TOUCH set and that DON_TOUCH should only apply to the internal hierarchy of the IP blocks that have it set. Is there a way for me force this replication so that I can meet timing?
Command: phys_opt_design -force_replication_on_nets [get_nets {BS_PANEL_i/CLK_AND_CTRL_GRP/CLK_MAIN/ARESETN_PERIPH_MAIN[0]}]
Phase 2 Fanout Optimization
INFO: [Physopt 32-76] Pass 1. Identified 1 candidate net for fanout optimization.
INFO: [Physopt 32-782] Net BS_PANEL_i/CLK_AND_CTRL_GRP/CLK_MAIN/RST_DIFF_BUFF_0/inst/aresetn_periph_out was not replicated
INFO: [Physopt 32-780] Instance BS_PANEL_i/JESD_INTERFACE_GRP/ADC_SIGNAL_CONDITION_wrapper_00/inst/ADC_SIGNAL_CONDITION_i/ADC_SIGNAL_CONDITION_00/DDS_SOURCE_GROUP/INTERFACE_CTRL_GRP/axi_clock_converter_0/inst has DONT_TOUCH and is preventing optimization
Resolution: Removing DONT_TOUCH attributes may enable additional optimization
INFO: [Physopt 32-780] Instance BS_PANEL_i/JESD_INTERFACE_GRP/ADC_SIGNAL_CONDITION_wrapper_00/inst/ADC_SIGNAL_CONDITION_i/ADC_SIGNAL_CONDITION_00/SWITCH_GRP/axi_clock_converter_0/inst has DONT_TOUCH and is preventing optimization
INFO: [Common 17-14] Message 'Physopt 32-780' appears 100 times and further instances of the messages will be disabled. Use the Tcl command set_msg_config to change the current settings.
INFO: [Physopt 32-232] Optimized 0 net. Created 0 new instance.
INFO: [Physopt 32-775] End 1 Pass. Optimized 0 net or cell. Created 0 new cell, deleted 0 existing cell and moved 0 existing cell
Voyager
Voyager
Re: force_replication_on_nets fails due to DONT_TOUCH
Hey @greglac,
Did you try removing the DONT_TOUCH for the instances in question?
Best,
Herbert
-------------- Yes, I do this for fun!
Visitor greglac
I'm not sure of how to remove it from the instances in a programmatic way. There are hundreds of instances with this DONT_TOUCH constraint causing the problem, and they inherit the constraint from xilinx IPs that contain it. The design is a large and an actively developing multi-user project so I expect the list of instances with the constraint to fluctuate often. Additionally I'd like to make sure that the logic optimizer respects the DONT_TOUCH within the hierarchy boundaries of the IPs that contain it.
Visitor greglac
I am still having this problem.
The following AR:
AR# 65212 https://www.xilinx.com/support/answers/65212.html
gives me the impression that phys_opt_design -force_replication_on_nets, should override the DONT_TOUCH
Can someone at least tell me if I am not interpreting the AR correctly?
Voyager
Voyager
Hey @greglac,
AR#65212 gives me the impression that phys_opt_design -force_replication_on_nets, should override the DONT_TOUCH.
This impression is wrong, DONT_TOUCH means DON'T TOUCH.
What AR#65212 states is that you can force the replication outside (specifically after) some instances with DONT_TOUCH attributes which would otherwise not happen.
If this is not enough for your purpose, all you can do/try is to remove the DONT_TOUCH from affected instances.
Best,
Herbert
