mikerez
how to limit routing by pblock?
I need to force all routing of one module or partition to use only one pblock
and save all routing outside the pblock to be clear.
avrumw
Expert
Expert
You can set the CONTAIN_ROUTING property on the PBLOCK. When you place a module inside a PBLOCK with this set, all the internal routing for the module needs to stay within the confines of the PBLOCK.
See UG912, v2014.4, p. 141 for more details.
Avrum
dwisehart
mikerez
but I need any way to limit routing to save it for other modules
avrumw
Expert
Expert
Avrum
mikerez
Oh yes, thank you! I'll try and come back.
mikerez
Hope this will work with V6
avrumw
Expert
Expert
Nope.
The command I sent you is a Vivado command. For V6 you have to use ISE. The equivalent of the PBLOCK mechanism in ISE is the AREA_GROUP, and while you have some control over the packing (GROUP=OPEN/CLOSED) and the placement (PLACE=OPEN/CLOSED), you do not have control over the routing.
Sorry.
Avrum
mikerez
ok thank you
