jeffson
how to skip [DRC 23-20] Rule violation (REQP-1753)
hi,
I met [DRC 23-20] Rule violation (REQP-1753) , but I want to skip it to let it be as warnnings. how to do that?
I tried below constraints in my xdc file, but it doesn't work. May I know how to skip this ERROR?
set_property SEVERITY {Warning} [get_drc_checks REQP-1753]
marcb
Hi @jeffson. I would check the following post, as this looks to be the same issue.
https://forums.xilinx.com/t5/Implementation/DRC-LUTLP-1-Combinatorial-Loop-Error-Must-be-Overridden/td-p/881855
You should be able to set the following property for the XDC file.
set_property USED_IN write_bitstream [get_files <path>/sev.xdc]
dpaul24
@jeffson,
Perhaps posting the complete error msg helps.
Who remembers what [DRC 23-20] Rule violation (REQP-1753) actually is!
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
marcb
jeffson
Thanks Marcb for providing the solution.
