shrutikatikar
image transmission using OFDM
I am attempting to transmit and receive an image using OFDM technique on system generator 14.2.
Kindly help me out with the design
balkris
you can find some demo design here on Your ISE installation
\Xilinx\14.7\ISE_DS\ISE\sysgen\examples\demos
I think it will helps you
Thanks and Regards
Balkrishan
balkris
You mean OFDM transmitter .
Break the system into small modules . Xilinx do have IPs like FFT/IFFT, DDS , DUC/DDC error correctly IPs which is required for OFDM
Thanks and Regards
Balkrishan
