implement a part of VHDL code
I am working on a project which contanins two mainly block, the first one is a cross-corollation block which is working fine, and the second one is an ethernet module to send the data provided by cross-corollation to user. Currently, I am working on the Ethernet module. My question is, can I synthesize and implement the cross-corollation module and save it on FPGA (Artix7 evaluation kit), and each time I just need to implement the ethenet module? So I dont need to synthesize and implement whole the code which takes long time.
@fk5747
Vivado Incremental compilation should be a good option for your case. Check the below link:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug904-vivado-implementation.pdf#page=97
--Syed
@fk5747
--Syed
@fk5747,
If I have understood correctly, there is an easy solution.
In the top module have a generic declared such as ENABLE_ETHERNET set to 0 to 1.
Then control the instiantiation of the Ethernet module as per generic value.
en_eth: if ENABLE_ETHERNET = '1' generate
  <instiantiate here>
else
  <drive all o/p signals to their default values>
end generate en_eth;
Whenever you want to synth your design, just change the value of the generic.
FPGA enthusiast!
All PMs will be ignored
