tvgod2000
is there a way to prevent OBUF from being mapped automatically, even if the variable is declared OUTPUT when coding?
Hi!
I am using ISE and I am using Verilog And I use Spartan6 SP605.
I'd like to ask you, is there a way to prevent OBUF from being mapped automatically, even if the variable is declared OUTPUT when coding?
What I want to do is to act as OUTPUT, but I don't want to do mapping and I want to see the results in P&R Simulation(about output).
blindobs
look for verilog attributes
(*dont_touch = "true"*)
(* KEEP = "TRUE" *)
 for keeping registers from being removed from synthesis tool if their output doen't drive any module output
