Visitor ls1065271400
ise14.7 implemention optimization?
I made a project use ise14.7 , when I synthesis , the resource of LUT  is about 80% , but when I implemetion the percent of the resource is 1%  , does it optimize by the ise ?  when I check the property of the implemetion , I dont find the opt item ,where can I close the opt of the ise ?
Re: ise14.7 implemention optimization?
Hi, @ls1065271400 ,
It looks some logic's output is not connected to the port of FPGA. For testing puupose, you can try to connect some sginals to the port directly as a clue to find why the related signals are not used.
To avoid trimming in Map, you can disable the -u option.
Here is an AR on how to check or manually set environment variables:
https://www.xilinx.com/support/answers/11630.html
Ebrahim
Guide avrumw
Guide
Almost certainly this optimization is due to the tool removing everything it determines to be "useless". This is almost always caused by a coding error.
For example, if you do not actually connect your clock, or if you accidentally keep all flip-flops in reset, or if none of your outputs (or inputs) are actually connected to ports, then everything inside the FPGA is redundant; the state of the FPGA is constant, and hence everything can be removed.
The easiest way to determine the problem and fix it is to do simulation - all of these conditions will be very apparent in even the most simple simulation.
Avrum
Hi, @ls1065271400 ,
thanks,I will try.
