mikerez
limit route_design iterations
Hi All
please help to limit route_design iterations till exit
in 2015.3 only directives are described in User Guide (dont help)
in conguestion case I need to wait hours before see conflicts
Thank you
siktap
There is no way to decrease the number of route iterations. The tool does its best to meet your requirements and eoute it sucessfully.
You can do report_design_analysis -congestion to get some congestion statistics.
Sikta
tusharvi
Hi @mikerez
Please check if 'incremental place and route' helps in your case.
Page 34 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2012_4/ug904-vivado-implementation.pdf
Tushar.
Please mark the post as an answer ("Accept as solution") in case it helped resolve your query.
Give kudos in case a post guided you to the solution.
This will help others in the long run
vijayak
Hi @mikerez
You can also refer to the video for quick reference.
http://www.xilinx.com/training/vivado/using-incremental-implementation-in-vivado.htm
The following document has a lab (lab-2) which explains the procedure with example design.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug986-vivado-tutorial-implementation.pdf
Thanks,Vijay
mikerez
how incremental compilation could help limiting route_design iterations??
siktap
Sikta
syedz
@mikerez,
You can use Flow_RuntimeOptimized implementation strategy  to reduce the iterations. Please check page number 153 in below Implementation user guide:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug904-vivado-implementation.pdf
--Syed
syedz
@mikerez,
If you want to limit iteration only on route_design then use the directive "RuntimeOptimized". Check page number 79 in same above User guide.
--Syed
mikerez
no this dont impact iterations count
the answer is found
ps.  so many false answers from moderators and Xilinx employees, is it a big game for kudos?
siktap
@mikerez I think there was some confusion with runtime and phase iterations of the route process. So there were some incorrect pointers.
