avinashc
mig 7 series- error ngdbuild 455
system- Artix 7, ISE 14.7, Win10
I am using MIG IP core for ddr3 and i am using example design. I am getting this error as below
pll_inst1 : pll
port map
(-- Clock in ports
CLK_IN1 => sys_clk_i,--CLK_IN1, pll_clk
-- CLKFB_IN => CLKFB_OUT,--CLKFB_IN,
-- Clock out ports
CLK_OUT1 => CLK_OUT1_s, ---400 MHz
CLK_OUT2 => CLK_OUT2_s, ---200 MHz
-- CLKFB_OUT => CLKFB_OUT,
-- Status and control signals
RESET => pll_rst,
LOCKED => LOCKED);
ERROR:NgdBuild:455 - logical net 'CLK_OUT2_s' has multiple driver(s): pin CLKOUT1 on block pll_inst1/plle2_adv_inst with type PLLE2_ADV, pin PAD on block CLK_OUT2_s with type PAD
If I give separate clk to sys_clk & ref_clk then it works fine(no error), but ass soon as I use pll for 2nd output to ref_clk, I am getting this error.
tried with no buffer ,bufg in the output of pll. This CLK_OUT2_s is not used anywhere in logic.
why it is giving multiple driver error?
syedz
@avinashc
Open synthesized design and check the connection of net mentioned in error message "CLK_OUT2_s"
The error is complaining that this net is driven by two or more drivers.
Also check this related forum link:
https://forums.xilinx.com/t5/Memory-Interfaces-and-NoC/NgdBuild-455-Multiple-drivers-error-related-with-DDR2-clocking/m-p/484152
--Syed
