Visitor e_shaikh
multi ngc file instantiation
hi every one!!
i made a porject with multi .ngc files istatiaed throung black box, now when i connect them they give errors of multi driven inputs and wrong buffer connections. these errors were not their which i made the same project by instantiating .vhd files
any help??
Re: multi ngc file instantiation
Did you disable "Add io buffers" when generating the netlists for submodules?
Deepika.
Deepika.
Deepika.
Deepika.
Visitor e_shaikh
thanks man it worked
