sangaanil
nexys-video-artix-7-fpga-trainer-board Axi Ethernet error
Hi everyone ,
I am using the nexys-video-artix-7-fpga-trainer-board for my application , i got this board from Digient . I am using ISE 14.6/14.7 design tool for implementation . When i am adding axi_ethernet IP to microblaze with connections in RGMII v 2.0 mode , am getting error in generating Netlist process (under EDK)  as Aborting Xst flow of execution . For remaing IPs there is no issue .
I would like to know the solution for this issue. If any ISE Reference Design for Ethernet on this board is available please share the details. Here am giving few lines in log and alo attaching part of MHS file related to ethernet Instance.
INSTANCE:axi_ethernet_0 -
F:\Experiments\nexys_ad9739a\EXP5_ISE\system\system.mhs line 413 - Running XST
synthesis
PMSPEC -- Overriding Xilinx file
<C:/Xilinx/14.6/ISE_DS/EDK/artix7/data/artix7.acd> with local file
<C:/Xilinx/14.6/ISE_DS/ISE/artix7/data/artix7.acd>
ERROR:EDK:546 - Aborting XST flow execution!
INFO:EDK:2246 - Refer to
F:\Experiments\nexys_ad9739a\EXP5_ISE\system\synthesis\system_axi_ethernet_0_
wrapper_xst.srp for details
Thanking you in advance.
siktap
This is weird. Are there any other error messages? Can you try with ISE/EDK 14.7?
Also just create a bsb project with ac701 and see if it goes succesfully with same ethernet IP.
Sikta
siktap
Sikta
sangaanil
Thank you Sikta .
I tried with 14.7 also but same issue am facing there also.
Can i get a Baisc axi_ethernet design for this Nexys Video Board with  ISE 14.7/6 .
sangaanil
HI ,
I did with AC701 , but there also am getting same issue.
sangaanil
In this implementation procedure i am following these steps,
  • Selecting bsb new project with required FPGA configuration options , am adding axi_ethernet IP to microblaze along with one axi_timer , axi_interrupt controller .
  • After launching the clock configure option , the GTX CLK and REF CLK are updated with 125MHZ and 200MHZ respectively .
  • configured the axi_ethernet and axi_timer_0 interrupts
  • And i updated the ucf file as per datasheet .
  • After doing all these steps am selecting Generate Netlist option ,
at the end of the procedure am getting the Aborting Xst flow of execution error as posted in my first message.
 I would like to share one thing before this Nexys board i worked with ML605 Verrtex 6 Board , Zed Board and Zybo Board for all these Boards ISE by default provides its mpd and Board basic interface requirement files .
But coming to thos nexys Board i dont find any such files in resource center of this Board .
So what are the other IPs that I have to add along with axi_ethernet (RGMII v2.0) , i mean as we are adding axi_timer , ddr memory related IP ,  and interrupt etc?
Thanking you in advance .
sangaanil
HI Sikta,
waiting for your reply.
sangaanil
Thank you Sikta .
madhan_ch
Hi all,
I have also got the same type of error while working with ethernet on Nexys-Video.
Upto now i haven't found the reason for error and solution the problem.
If anyone found the solution please share ...
