no detailed reports in ISE
        I have finished a project using ISE 14.7, and it works well on a FPGA board. But in my ISE project, I can not check  any detailed reports, such as synthesis report, power report. Is there any option setting to solve this problem?
implement design successfully
but no reports generated
Re: no detailed reports in ISE
Thanks. I just right clicked on "Design overview" window and choose "reset report list", it fixed the problem.
Hi @gamefan567,
I am not sure why the Detailed Report section is coming as grey out but  the reports will still be available. You can open the reports using a text editor:
*.syr - synthesis report (XST)
*.bld - translation (ngdbuild) report
*.mrp - map report
*.par - place & route report
*.twr - Poset P&R timing report, text
*.bgn - BitGen report
Check this AR# link, might be the reason for grey out:
https://www.xilinx.com/support/answers/38702.html
Raj.
Hi @gamefan567
Below link gives the possible cause of the reports been greyed out in the Design summary view. Have a look.
Rohit
