open vivado checkpoint takes forever
Hi, my design on xczu9eg-ffvb1156-2-i-es2 is quite large.
I first created block diagram using project mode, and export .tcl file that regenerates block diagram using write_bd tcl command.
Then, I regenerate block diagram in non-project mode and run synth_deisn, opt_design, place_design, and route_design.
I tam trying to open synthesized design checkpoint that I saved after synthesis, but
"Reading file C:/.../.Xil/Vivado-28952-DESKTOP-574N638/dcp/deisn_1_wrapper_early.xdc" takes really long.
Any suggestion?
Mentor jmcclusk
Mentor
Re: open vivado checkpoint takes forever
Sadly, I don't know of any method other than a faster computer.   Maybe an I9 CPU with quad channel DDR4 memory?   In my experience,  using an SSD instead of a magnetic disk doesn't help much.. maybe a speedup of 5 or 10% in compile time.
@jmcclusk
I understand it takes long to compile. But I meant "opening up Vivado DCP file" takes long, which is not something expected to me.
Mentor jmcclusk
Mentor
I know what you mean.  Opening a checkpoint is famously slow on big designs, even on monster machines.   I got used to finding other tasks after starting a checkpoint load.
Hi @moon5756. I would try using the command report_methodology, and searching the results for "runtime" or "run time". There are a few methodology checks that will advise on how to better constraints. For instance wildcards that search a large number of design objects can hurt run time. Also, narrowing object searches to "get_pins -of [get_cells -filter {expression}]]" can help reduce run time.
This section of the Methodology Guide also has suggestions on Timing Exceptions with respect to runtime.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug949-vivado-design-methodology.pdf#page=169
