opt_design error (Implementation Failed)
After writing my program and verifying my outputs in behavioral simulation, I'm getting the following error:
"[opt 31-2] SRL16E m3/inst/ila_core_inst/shifted_data_in_reg[7][177]_srl8 is missing a connection on D pin"
I've verified my VIO and ILA mapping even which are correct.
Any suggestions would be appreciated.
hongh
Hi, h20181230210@hyderabad.bits-pilani.ac.in ,
Which version of Vivado are you using? Could you try the latest version?
Could you try to run opt_design with single option to check which one causes the issue?
Ex:
opt_design -sweep
opt_design -retarget
opt_design -propconst
