placement error even clock from IOB to PLL of same region ?
HI Friends,
For any help or suggestions are highly appreciated.
Thank You
S Sampath
-Sampath
Re: placement error even clock from IOB to PLL of same region ?
Hi @ssampath.
The CLOCK_DEDICATED_ROUTE constraint can be set as indicated in the error, but this is not recommended.
@ssampath
The site IOB_X0Y141 for xc7k410tffg676-2 is not clock capable IO hence you are receiving the error. If you chage the port to clock capable IO (SRCC or MRCC) then you will not see the error message.
Check 7 series clocking resource user guide for more details:
https://www.xilinx.com/support/documentation/user_guides/ug472_7Series_Clocking.pdf#page=24
--Syed
HI @syedz
Thank You, but we are connecting this board to external. Now i don't have any option, Is there any fix for this ?
-Sampath
Hi @ssampath.
