jamieliao
reasonable OS memory usage
Hi Sirs,
I'm wondering to know, Does this OS memory usage is reasonable?
My problem is this vivado job always need a very long runtime.
The runs(job) usually kill by LSF(maybe openlava)
I checked the "Memory Recommendations" @ https://www.xilinx.com/products/design-tools/vivado/memory.html
There are huge difference between my system loading report
My LUT utilization is very high
XCVU440-flga2892 @ Vivado v2018.3(64-bit)
thanks very much
TC Liao
syedz
@jamieliao
High runtime can be due to various reasons. Did you check the log file and check elapsed time and memory values for each phase?
Check this AR on debugging runtime issues: https://www.xilinx.com/support/answers/71571.html
--Syed
syedz
@jamieliao
--Syed
