replace cells in DCP
I would like to know if exits the way to replace cells in post routed DCP design with another cells I have in other design to avoid to recompile the entire project and also have modifications in project compilation.
regards,
Julian.
Re: replace cells in DCP
Hi, @jmartinez ,
The basic commands for the flow to replace a cell
1. remove_cell : remove the original cell
2. create_cell   : create a new cell
   Ex: create_cell -reference FDCE my_FF   ;#create a register whose instance name is my_FF
3. connect_net : connect net to the pin of the new created cell
   Ex: connect_net -net an_existing_DATA_net_name -objects {my_FF/D}
4. place_cell : place the cell into the specific LOC
    Ex:place_cell my_FF SLICE_X49Y61
5. route_design
Hi @jmartinez ,
I think incremental compile will be helpful in that scenario. The incremental design incorporates small design changes or variations from the reference design. These changes or variations can include:
• RTL changes
• Netlist changes
• Both RTL changes and netlist changes
Check page no.97:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug904-vivado-implementation.pdf
Raj
Hi, @jmartinez ,
You can use ECO flow and refer to UG904 for the Netlist Modifying Commands:
• create_port
• remove_port
• create_cell
• remove_cell
• create_pin
• remove_pin
• create_net
• remove_net
• connect_net
• disconnect_net
thanks @hongh this is the way I would like to explore but didn't find any example how to do it. I was able to remove the cell from the entity I want to replace but wasn't able to insert the new cells from new entity I have in another dcp(the place_cells command don't know how to use it) and don't know if this is even possible.
could you point me to the rigth direction with example commands?.
thanks.
Hi, @jmartinez ,
5. route_design
thanks @hongh,
I understand this is the simple way of doing this but I want to replace a complete entity instead of doing it cell by cell. I don't know if it's even possible (maybe with a tcl script to automatize the task).
Also I'm looking for the way of extract all the cells info inside the entity to export it to the other dcp.
but your answer is correct.
Thanks!.
Hi, @jmartinez ,
The above flow I mentioned is not appropriate to replace a module which contains a bunch of primitives.
You can try to use the PR flow described in UG909 to replace the implement the submodule in context.
