Visitor bj8201.kim
reset _run sub-module and fail to implementation
I received FPGA project (using vivado 2017.4) build successfully before.
No problem when just reset_run synth_1, reset_run impl_1.
But the problem is occured sub-modules reset like below.
   foreach run [ get_runs ] {
       reset_run [ get_runs $run ]
what do I check first?
Thanks in advance.
Re: reset _run sub-module and fail to implementation
Hi @bj8201.kim ,
I guess you are trying to reset run for OOC module, if yes then please check below:
You can ashieve that by
reset_runs <module_name>_synth_1.
For example:
For above any sub module run:
reset_runs MystGthSerdesFreqCounter_KU15P_synth_1
raj
Visitor bj8201.kim
Thanks raj.
C2C_slave_dfpga_v01 -> Regenarate Output Product -> Fail to Launch Run impl1.
What do I do next step?
Plz advice to me.
Hi @bj8201.kim ,
I used your TCL commands to reset runs and I was able to reset the runs successfully.
can you check if the TCL console returns the name of the submodule runs when you run get_runs
If not then can you check if the IPs ( for which you are trying to reset the submodule runs ) are locked or not?
If the IP's are locked, then you need to unlock these IP's and then try resetting the run.
--Suraj
