Visitor sonycman
unexpected site type 'IOPAD' in HDPYFinalizeIO
Hello.
I`am using Vivado 2018.3 and had created a simple design with the bare Processing System for Zynq-7000.
Implementation completes successfully, but gives a hundreds of warning messages like this:
[Designutils 20-3303] unexpected site type 'IOPAD' in HDPYFinalizeIO
What does they mean, and how to get rid of them?
In Vivado 2018.2 no such a warnings appears in the similar design!
 Any advice would be welcome.
Re: unexpected site type 'IOPAD' in HDPYFinalizeIO
Hi @sonycman,
The design which you are using in Vivado 2018.3 is a fresh built project or it is the migrated project from Vivado 2018.2?
Thanks and regards,
Raj.
Visitor sonycman
Hi rshekhaw,
This is a newly created simple design, it takes only a couple of minutes to create it.
Just created another one to check - all the same, implementation generates almost 300 warnings of a type [Designutils 20-3303] unexpected site type 'IOPAD' in HDPYFinalizeIO.
I`am using xc7z007sclg225-1 device.
@sonycman
We have filed a CR to get the issue fixed in vivado for better messaging.
--Syed
Visitor sonycman
Thank you!
Hope this issue will be fixed eventually.
This solution is not acceptable.  It gives no work around at all.  It is all fine to say a CR is filed against the problem but to not give any work around  leaves me just as stuck.
Can you please answer the question "How should the problem be fixed" ?  The answer should address the situation for a fix today, not  by saying it will be fixed when 2019.1 releases.
Nick
Participant sagar8446
Any update on this thread.  Are the warnings critical or can be ignored.
Visitor martacami
I have the same problem in Vivado 2018.3 with a design migrated from 2015.2 version. An explanation would be helpful.
Marta
Visitor sergebertet
Me too, waiting for an answer
[Designutils 20-3303] unexpected site type 'IOPAD' in HDPYFinalizeIO (99 more like this)
Please tell us the meaning of this warning.
Serge
Visitor m.schappeit
Me too!
More informatione needed.
Please remove solved tag for better visibility.
Taking a look at the CR, this warning message will be removed in 2019.1. Based upon the test cases we've received with this warning, there is nothing that the user could or should do to prevent it.
Ryan
