vivado 2015.4 running P&R issue
Hello
Used the vivado 2013.03 running P&R is OK, but used the vivado 2015.4 running P&R is error
Change the vivado version running P&R miss this error message:
FPGA device:xc7v2000t
ERROR: [Constraints 18-608] We cannot route the nets within the site IOB_X0Y86.
Reason: Could not route the logical net: ../../../WEJ on site IOB_X0Y86 to the load pin OUTBUF_DCIEN.OUT.
Please check your design to see if the pin has a legal route to its driver or loads.
Re: vivado 2015.4 running P&R issue
@quincyq2003,
Check if the similar forum thread helps:
https://forums.xilinx.com/t5/Implementation/ERROR-cannot-route-the-nets-within-the-site-IOB-X1Y227/td-p/640909
--Syed
@quincyq2003,
--Syed
Hello @syedz
Thanks for your help!!!
