vivado hang at implementation stage
HI Friends,
Vivado hanged at implementation stage, The following is the part of the log.
Phase 3.3 Area Swap Optimization
Phase 3.3 Area Swap Optimization | Checksum: de18dbfe
Time (s): cpu = 00:12:38 ; elapsed = 00:05:55 . Memory (MB): peak = 3162.438 ; gain = 7.012 ; free physical = 37826 ; free virtual = 305010
Phase 3.4 Pipeline Register Optimization
Phase 3.4 Pipeline Register Optimization | Checksum: 10af736b8
Time (s): cpu = 00:12:39 ; elapsed = 00:05:56 . Memory (MB): peak = 3162.438 ; gain = 7.012 ; free physical = 37826 ; free virtual = 305010
Phase 3.5 Timing Path Optimizer
Phase 3.5 Timing Path Optimizer | Checksum: 1322065c0
Time (s): cpu = 00:13:08 ; elapsed = 00:06:05 . Memory (MB): peak = 3162.438 ; gain = 7.012 ; free physical = 37826 ; free virtual = 305009
Phase 3.6 Fast Optimization
Phase 3.6 Fast Optimization | Checksum: 120bd5fa7
Time (s): cpu = 00:13:12 ; elapsed = 00:06:08 . Memory (MB): peak = 3162.438 ; gain = 7.012 ; free physical = 37824 ; free virtual = 305008
Phase 3.7 Small Shape Detail Placement
Phase 3.7 Small Shape Detail Placement | Checksum: 1f61613fa
Time (s): cpu = 00:14:44 ; elapsed = 00:07:35 . Memory (MB): peak = 3162.438 ; gain = 7.012 ; free physical = 37826 ; free virtual = 305009
Phase 3.8 Re-assign LUT pins
Phase 3.8 Re-assign LUT pins | Checksum: 19e1fde1b
Time (s): cpu = 00:14:55 ; elapsed = 00:07:46 . Memory (MB): peak = 3162.438 ; gain = 7.012 ; free physical = 37826 ; free virtual = 305010
Phase 3.9 Pipeline Register Optimization
Phase 3.9 Pipeline Register Optimization | Checksum: 17a57fb70
Time (s): cpu = 00:14:59 ; elapsed = 00:07:48 . Memory (MB): peak = 3162.438 ; gain = 7.012 ; free physical = 37826 ; free virtual = 305010
Phase 3.10 Fast Optimization
Phase 3.10 Fast Optimization | Checksum: 162effcf9
Time (s): cpu = 00:16:04 ; elapsed = 00:08:14 . Memory (MB): peak = 3162.438 ; gain = 7.012 ; free physical = 37824 ; free virtual = 305008
Phase 3 Detail Placement | Checksum: 162effcf9
Time (s): cpu = 00:16:07 ; elapsed = 00:08:16 . Memory (MB): peak = 3162.438 ; gain = 7.012 ; free physical = 37824 ; free virtual = 305008
Phase 4 Post Placement Optimization and Clean-Up
Phase 4.1 Post Commit Optimization
INFO: [Timing 38-35] Done setting XDC timing constraints.
Re: vivado hang at implementation stage
HI ,
I tried 2017.4 but getting same issue, The problem in my case is tool automatically assining pin locs for some ports because of mismatch of ports in xdc and top file. mainly clock pins are changed in my case. now it is fine.
Thank You
S Sampath
Voyager
Voyager
@ssampath
How long did you allow it finish?
What version you running? (2018.3 appears to be much faster than 2018.2 in my testing)
Is you design 'large' (or have large case statements, processes, ...)?
HI ,
am using 2016.4 and design not that much big. since 5 hrs it is in same state.
Once i will try with 2018.2 version.
Voyager
Voyager
@ssampath
Yes, try with a newer version.
One other reason I have seen reported, was when the design was recursive (and then ran out of memory and when in to swap)
@ssampath
Did you try in vivado 2018.x as suggested above? Also, try to remove any wild cards in XDC or clean up the timing constraints to make it simple
--Syed
HI ,
Thank You
S Sampath
