vivado partial reconfiguration issue
Hello
Read UG909-vivado partial reconfiguration document.
vivado partial reconfiguration flow can't support VU440 device?
Re: vivado partial reconfiguration issue
@quincyq2003,
VU440 was not fully enabled for all customers. If you need access then please create a service request or ask your FAE.
https://www.xilinx.com/support.html#serviceportal
--Syed
@quincyq2003,
--Syed
Hello @syedz
This issue is resolve, thanks for your help!!
