sam025023
vivado zynq implementation error: [Drc 23-20] Rule violation
Hi There,
I am using vivado 2016.2 in Win10 for zynq7020.
My clocking scheme is zynq PS FCLK_CLK0-- > input of clocking wizard IP input (Primitive PLL).
Synthesis is ok, but it failed in implementation.
[Drc 23-20] Rule violation (REQP-1712) Input clock driver - Unsupported PLLE2_ADV connectivity.- ***** with COMPENSATION mode ZHOLD must be driven by a clock capable IO.
Please help!
balkris
Can you try running the design in latest Vivado tool
The ISE or Vivado design tools automatically select the appropriate compensation based on circuit topology. However in your case it looks like it chose this incorrectly as ZHOLD. When the clock input of PLL is coming from BUFG then the compensation factor should be BUF_IN.
Refer to page-85 of http://www.xilinx.com/support/documentation/user_guides/ug472_7Series_Clocking.pdf
Thanks and Regards
Balkrishan
balkris
Thanks and Regards
Balkrishan
