Voyager
Voyager
why MMCM/PLL need BUFG feed back ?
HI Friends,
1) why MMCM/PLL need BUFG feed back ?
2) can i use BUFH instead of BUFG ?
3) can i remove BUFG ? Is there any problem if i remove it ?
For any help or suggestion it is highly appreciated.
Thank you
S Sampath
Re: why MMCM/PLL need BUFG feed back ?
@ssampath
Check MMCM with Internal feedback:
https://www.xilinx.com/support/documentation/user_guides/ug472_7Series_Clocking.pdf#page=93
Also check this forum discussions:
https://forums.xilinx.com/t5/Timing-Analysis/MMCM-feedback-with-BUFG/td-p/769657
--Syed
