Visitor zjywindwalk
why fdce placement si so far from it's driving cells IDDR?
 I flopped the IDDR(#1 in the fig) output using FDCEs(#2 in the fig), but the tools select the FDCEs far from the IDDR, which cause setup violations. Why doesn't the tool choose the neighbor FDCEs, such as #3 in the fig?
Jevon
Visitor zjywindwalk
Re: why fdce placement si so far from it's driving cells IDDR?
It is caused by the constrain, it works right now
Voyager
Voyager
First of all, you're not looking at the chip--you're looking at a graphical representation of the chip's major resources on a screen. And you can't see the connection dependencies and routing rules that must be followed by the tool, on the screen.
Secondly, if you think you can find a better placement for that item than the tool can, move it.  Select it, then drag it to where you want it. Save that modified design and then see what happens. Give it a go; you've got nothing to lose.
-Joe G.
Visitor zjywindwalk
