Observer michalmix
xapp1126 example won't works
I'm trying to run this EDK project: (xapp1126 - SDMA interface)
https://secure.xilinx.com/webreg/clickthrough.do?cid=114065 // link from xapp1126.pdf manual
When I synthesize project and run, there is no output messages in my RS Terminal. (rs232 connection is ok, other projects works)
I changed uart16550 to uart lite - without effect.
I modified software to simple main: (uart lite 9600-8-N-1)
int main(void)
   print("Test");
   return 0;
- without effect
Only 'ready_for_download' .elf and .bit works perfectly..
Maybye someone has 'working project' that simply copy memory using SDMA?
Observer michalmix
Re: xapp1126 example won't works
Ok, I checked this program using debugger, It works  in 'stepping debugger mode', but I don't know why it doesn't work when I download bitstream and simply run..
