xdc io_standard
In my xdc file is:
"set_property -dict {PACKAGE_PIN K2 IOSTANDARD LVCMOS33} [get_ports i2c_sda]"
but when I type
"get_io_standards -of_objects [get_ports [list {i2c_sda}]]",
the tcl console returns
LVCMOS18
Also, I get errors indicating that there is no "LOC" specified for this signal.
Please tell me what is wrong with this picture.
>>Eric
Re: xdc io_standard
Hi @eholtzclaw ,
Try using IO planning in Vivado.
1- Open an elaborated, synthesized or implemented design.
2- Select "Layout" -> "I/O Planning"
And check the constraint generated in xdc.
Raj
Re: xdc io_standard
Hi @eholtzclaw
Does the synthesis or implementation log indicate any problem when you search for the port name? I would expect messaging if the constraint was not applied.
