Stavie_94
Will the NEXYS 3 board work with the 2020.1-2020.2 update?
miker
@Stavie_94
If this is the board you are referencing Nexys Video Artix-7 FPGA then yes.  In Vivado 2020.2, you can select the Tools > XHUB Stores... then select the Boards tab and search for "nexys".  You can use the download button to download to your Vivado 2020.2 installation.
Please Reply, Kudos, and Accept as Solution.
miker
@Stavie_94
Stavie_94
Hey, thanks for the quick reply. I should've mentioned which model.
It's actually the Xilinx Spartan6 XC6LX16-CS324...would that be supported?
miker
@Stavie_94
Spartan-6 is not supported in Vivado.  Only ISE.
Stavie_94
Thank you.
