30 days Evaluation License Synthesis Error
I recently obtained a license file for the 30 day evaluation of Vivado 2015.3.  I have placed the license file in the .xilinx directory and on running license manager the license appears and indicates it is valid.  When trying to synthesise I get the following error:
[common 17-345] A valid license file was not found for feature 'synthesis' and/or device 'xc7a35t'.  Please run vivado license manager for assistance in determining which features and devices are supported for your system.
Any help appreciated.
Graham
Re: 30 days Evaluation License Synthesis Error
Ok so that now works.  The question is why are you able to generate a certificate based lic file if it won't work?
Graham
Hello @dstlgsmith,
It seems the license is not properly installed on your system. Please check this video which has details about generating and installing activation based node-locked license
http://www.xilinx.com/training/vivado/vivado-licensing-and-activation-overview.htm
Ashish
Which OS are you using?
Can you please run this command in tcl console:
report_environment -file env.txt
and share the output(env.txt) here?
Nupur
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
My OS is Windows 7.
The license is a .lic certificate based one due to the machine not being connected to the internet.
I will run the sugested tcl commands and report back.
Graham
Hello @dstlgsmith,
Even if the machine is not connected to internet you can generate activation based license. Please check below AR
http://www.xilinx.com/support/answers/61597.html
Ashish
Graham
