30 days Evaluation License Synthesis Error
I recently obtained a license file for the 30 day evaluation of Vivado 2015.3.  I have placed the license file in the .xilinx directory and on running license manager the license appears and indicates it is valid.  When trying to synthesise I get the following error:
[common 17-345] A valid license file was not found for feature 'synthesis' and/or device 'xc7a35t'.  Please run vivado license manager for assistance in determining which features and devices are supported for your system.
Any help appreciated.
Graham
Re: 30 days Evaluation License Synthesis Error
Ok so that now works.  The question is why are you able to generate a certificate based lic file if it won't work?
Graham
Hello @dstlgsmith,
It seems the license is not properly installed on your system. Please check this video which has details about generating and installing activation based node-locked license
http://www.xilinx.com/training/vivado/vivado-licensing-and-activation-overview.htm
Ashish
Which OS are you using?
Can you please run this command in tcl console:
report_environment -file env.txt
and share the output(env.txt) here?
Nupur
Nupur
My OS is Windows 7.
The license is a .lic certificate based one due to the machine not being connected to the internet.
I will run the sugested tcl commands and report back.
Graham
Hello @dstlgsmith,
Even if the machine is not connected to internet you can generate activation based license. Please check below AR
http://www.xilinx.com/support/answers/61597.html
Ashish
Graham
