Observer mmaciag
A bit confused about what I get for SDSoC or Vivado HLx license.
I am looking for a tool that will let me develop applications on larger Zynq UltraScale+ chips (11EG or 15EG). I am a bit confused about what I actually get when I buy Vivado HLx or SDSoC licence.
At the time of writing node-locked licenses are:
Vivado HLx - $2995 (Design Edition)
SDSoC - $995
Once I used evaluation licence (60-day or something) to test SDSoC. During installation Vivado/Vivado HLS were installed too. Somewhere I read that SDSoC is a superset of Vivado HLx capabilities. For example, as I understand, SDSoC calls internally Vivado HLS to transform C++ code to HDL.
Could someone explain what are limitations of Vivado included in SDSoC installation and how SDSoC can be cheaper than Vivado HLx if it is a superset of stand-alone Vivado? Is it matter of list of supported devices (e.g. limited to Zynq) or special features like Partial Reconfiguration not included in SDSoC standard license? Do I need separate separate licences to use both Vivado/Vivado HLS (e.g. to build custom IP cores, block design, export custom hardware) and SDSoC (to build CPU application)?
Thanks in advance for answers,
MM
Re: A bit confused about what I get for SDSoC or Vivado HLx license.
Hello @mmaciag,
Indeed, the SDSoC system compilers target a base platform and invoke the Vivado® High-Level Synthesis (HLS) tool to compile synthesizeable C/C++ functions into programmable logic.
This and other info can be found here: https://www.xilinx.com/html_docs/xilinx2018_1/sdsoc_doc/nmv1517252127853.html
More info can be found here: https://www.xilinx.com/html_docs/xilinx2018_1/sdsoc_doc/index.html
The answer is YES, indeed you'd need separate licenses, one for Vivado and one for SDSoC.
To see what features/tools Vivado HLx license of any edition supports, please see this link: https://www.xilinx.com/products/design-tools/vivado.html?resultsTablePreSelect=documenttype:SeeAll#buy
Hope the above is clear.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hello @mmaciag,
Kind Regards,
Anatoli Curran,
Observer mmaciag
Thanks for clear answer, it resolves my doubts.
Best regards,
MM
