alaertsg
A valid license was not found for feature 'Synthesis'
I am unable to run the feature 'Synthesis'
error :
[Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7z010'. Please run the Vivado License Manager for assistance in determining
which features and devices are licensed for your system.
Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ".
altough I running a supported version of Os > Centos 7
I have obtained a valid license key for my PC and this one is installed in the vivado software
Synthesis    Tools    Permanent    2016.08    Nodelocked    /home/gery/.Xilinx/Xilinx_lin.lic    Uncounted    0    303a640e6681    No    Okay    11    pepijntje,Vivado_System_Edition,software,permanent,_174204927_1777498229_210611584_341
that corrensponds with my MAC address
[gery@centos7-laptop 2015.4]$ ifconfig
enp1s0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 7c:d3:0a:00:8e:8a  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 0  (Local Loopback)
        RX packets 8  bytes 592 (592.0 B)
        TX packets 8  bytes 592 (592.0 B)
virbr0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 192.168.122.1  netmask 255.255.255.0  broadcast 192.168.122.255
        ether 52:54:00:98:da:d5  txqueuelen 0  (Ethernet)
wlp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.29  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 2a02:a03f:181f:6e00:323a:64ff:fe0e:6681  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::323a:64ff:fe0e:6681  prefixlen 64  scopeid 0x20<link>
        ether 30:3a:64:0e:66:81  txqueuelen 1000  (Ethernet)
        RX packets 2001  bytes 2198724 (2.0 MiB)
        TX packets 1508  bytes 340105 (332.1 KiB)
Could somebody help me to solve this issue?
Gery
syedz
@alaertsg,
Thanks for sharing xinfo.txt. The issue is due to the HostID mismatch as mentioned in @vuppala,
Please check the AR#60510.
http://www.xilinx.com/support/answers/60510.html
Also the below AR will guide you in rehosting the License based on its type:
Certificate License:http://www.xilinx.com/support/answers/36136.html
Activation License:http://www.xilinx.com/support/answers/60525.html
--Syed
syedz
@alaertsg,
Please share the complete License file along with xinfo.txt.
To generate xinfo,txt, Run below command in Vivado Tcl shell and share the output file.
report_environment -file xinfo.txt
Syed
vuppala
Hi Gery,
The issue looks like hostid mismatch. i.e., The hostid in the license file is: 303a640e6681 whereas the Vivado License Manager was unable to read the ethernet port name since it was named as wlp2s0 (whose hostid is:303a640e6681).
Rename the ethernet port name from wlp2s0 to eth0, eth1, etc., to resolve this issue.
Check this answer record for more information: http://www.xilinx.com/support/answers/60510.html
Vinay
alaertsg
Hi Syed,
Here you have the requested information in the attachement
alaertsg
syedz
@alaertsg,
--Syed
alaertsg
@syedz
Thanks for the info.
I have renamed the interfaces of my Centos installation to the olde naming convention.
Unfortunately I have ask to register a license on the Wlan adapter of my laptop.
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP qlen 1000
    link/ether 30:3a:64:0e:66:81 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.29/24 brd 192.168.1.255 scope global dynamic wlan0
       valid_lft 3561sec preferred_lft 3561sec
    inet6 2a02:a03f:18b9:3b00:323a:64ff:fe0e:6681/64 scope global noprefixroute dynamic
       valid_lft 345625sec preferred_lft 345625sec
    inet6 fe80::323a:64ff:fe0e:6681/64 scope link
       valid_lft forever preferred_lft forever
Is does not seems so easy to rename this interface to eth(something).
Is there a way to attach the license to a Wlan interface.
The problem is that I did not requested this license myself, I got it via the university, so it will by not so easy to rehosting this license to the wired network adapter.
vuppala
Hello @alaertsg
You have two options to resolve this issue.
1. Changing the wlan0 to eth0/eth1/etc., (see the instructions in AR#60510)
2. Rehost the license file to eth0 i.e., whose hostid is:7cd30a008e8a (see the instructions in AR#36136)
Vinay
alaertsg
@vuppala
I was unable to change the wlan0 to eth0. That is not so straight forward.
Finaly I have asked for a new license that is bound to the fixed network card...
