AXI 1G/2.5G Ethernet Subsystem Example Design License error
I am trying to evaluate the AXi 1G/2.5G Ethernet subsystem.  I have generated a hardware evaluation license as per the links from the product page but when I go to generate the bit strteam it fails with no bitstream generation allowed for AXI_ethernet_0_tri_mode_ethernet_MAC_v9_0_2.
I am using Vivado 2015.3 release.
Re: AXI 1G/2.5G Ethernet Subsystem Example Design License error
Can you share output of following command
report_environment -file C:/folder_name/env.txt
share env.txt generated in folder.
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
Any updates on this?
-Shreyas
