kflok
About ZCU104 License
Dear All,
Recently, I have purchased an evaluation kit: Zynq UltraScale+MPSoc ZCU104 and now I would like to redeem the license voucher. Before redeem, I have the following questions about the license:
1) In the Quick Start Guide, it is stated that the license is node-locked, can it be changed to floating type (it will be more flexible for different users can access the evaluation kit at different PC at different time)?
2) Can I re-host the license to another PC with different mac address & OS, say after 1 year?
Thank you in advance.
syedz
@kflok
No, I dont think you can change this license to floating license.
https://www.xilinx.com/products/design-tools/faq.html
Yes you can: https://www.xilinx.com/support/answers/36136.html
--Syed
syedz
@kflok
--Syed
anatoli
Hello @kflok,
Is there any further assistance required in relation to this matter? If so, please let us know and we will be glad to help you further then.
If not, and if @syedz answered your query, please mark his response as 'Accepted Solution' (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that the topic can be completed then? We appreciate your help.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
