drgnstefan
Account has failed export compliance verification
Hello.
I'm trying to download vivado from here:
https://www.xilinx.com/member/forms/download/xef.html?filename=Xilinx_Unified_2020.2_1118_1232_Win64.exe
and site throws error everytime i hit download button, i tried everything, deleting cookies, reinstalling browser, using other browsers, switching pc, i readed every topic with the same problem but didn't help....
I also noticed that my classmates have a captcha code before download but i don't have one.
Thank you.
xilinxacct
Instructor
Instructor
@drgnstefan
Several other people have had this...
This was the answer when someone else had the issue
This is part of the FAQ for the Welcome and Join board:
Q2. When I try to download a tool or a document I get the following message:
“We cannot fulfill your request as your account has failed export compliance verification”
What can I do?
A2. You should start by reading the recommendations from AR#44043.
If you still have issues, in order for your profile to be reset and cleared, please send an email to Xilinx Customer Support (websupport@xilinx.com) indicating your "export compliance issue" and they in turn will contact Xilinx Customer Service on your behalf, who would be able to screen and verify your profile and re-activate this then, so that you can login and download the required software without issues
Hope that Helps
If so, Please mark as solution accepted. Kudos also welcomed.
xilinxacct
Instructor
Instructor
@drgnstefan
What can I do?
Hope that Helps
