perilous
Bad link on download
When I download the installer on this page for windows:
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools/2018-3.html
The file is called Xilinx_Vavado_SDK_Web_2018.3_1207_2324_win64.exe and it wants to install Vivado not the SDK as I expect.
anatoli
Hello @perilous,
Thanks for letting us know.
This issue has already been reported to us (https://forums.xilinx.com/t5/Installation-and-Licensing/2018-3-SDK-Standalone-WebInstall-Client-problem/m-p/919763/highlight/false#M24316) and we are currently working on getting this sorted. We will update you once this is fixed.
Apologies for any inconvenience caused.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
frosteyes
Hi all.
I changed the link manually for now to https://www.xilinx.com/member/forms/download/xef.html?filename=Xilinx_SDK_2018.3_1207_2324_Lin64.bin
For the linux version of the SDK.
anatoli
Hello @frosteyes@perilous,
This issue is now addressed. Please try again and you should now see the right installer file for SDK standalone.
Thanks once again for reporting this issue to us and apologies once again for any inconvenience caused.
Have a lovely day ahead.
Kind Regards,
Anatoli Curran,
Versal Blogs
