jtanko12
Batch file error on Windows 7
I have intalled WebPack on a laptop with Window 7, please see attachment for
my system details.
Short version of the problem is that I get a message when I try to start ISE that says:
"windows can't open this file: Settings64.bat".
What could this be? Never seen this kind of error before and I installed Xilinx
software on many machines over the years.
/Jakab
danders
You need to run this via command line.  When you run in in the command prompt it will set you environment up where you can then launch ISE.  Once you do run this .bat file you can then type set to see the enviroment variables set
C:\Xilinx\14.2\ISE_DS>settings64.bat
XILINX=C:\Xilinx\14.2\ISE_DS\ISE
XILINXD_LICENSE_FILE=C:\.Xilinx\
XILINX_DSP=C:\Xilinx\14.2\ISE_DS\ISE
XILINX_EDK=C:\Xilinx\14.2\ISE_DS\EDK
XILINX_PLANAHEAD=C:\Xilinx\14.2\ISE_DS\PlanAhead
XILINX_VIVADO=C:\Xilinx\Vivado\2012.2
XIL_PAR_DESIGN_CHECK_VERBOSE=1
-David
bwiec
Settings64.bat is a script that is run to setup your environment whenever you launch any of the tools.
It exists here:
C:\Xilinx\14.2\ISE_DS\settings64.bat
Is the file there? Were there any issues with the install? Maybe try running an MD5 checksum on your install package to be sure it was downloaded completely/correctly.
www.xilinx.com
jtanko12
Yes, the file is there and so is settings32.bat but Windows 7 gives me this
message :
danders
-David
jtanko12
Thanks for the help. It worked with an extra step; after the batch file is run as you indicated
in the Windows start menu (ISE icon properties) the call to the batch file needs to be deleted
so only the .exe is called when you click it
/Jakab
