Observer kianoosh5
Bitgen and License?
WARNING:Bitgen:26 - Bitgen only supports DRC but not bitstream generation on
   this device.  This condition can occur if there are problems obtaining a
   license to run bitgen or if the design targets a device which is Early
   Access.
WARNING:Bitgen:26 - Bitgen only supports DRC but not bitstream generation on   this device.  This condition can occur if there are problems obtaining a   license to run bitgen or if the design targets a device which is Early   Access.
What am i supposed to do?
Re: Bitgen and License?
Yes, the ISE 12.2 Webpack license supports the XC5VLX50 device that is on the ML501 board.
Which device are you using?
Which software version are you using?
Do you have a full, eval or webpack license?
Observer kianoosh5
I thought i was using webpack and i have ML501 and ISE 12
Observer kianoosh5
Sorry apparently i was using the 30 day version that expired, but with webpack you can create bit files right?
