Bug in Install additional devices for 2019.2
While trying to install Kintex Ultrascale device on an existing device, The installer gets stuck on a screen titled "select extra content"
There are no contents to select and the next button does not advance the installer.
My Configuration is
uname -a
Linux dyumnin 5.3.0-51-generic #44~18.04.2-Ubuntu SMP Thu Apr 23 14:27:18 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
lsb_release -a
No LSB modules are available.
Distributor ID: LinuxMint
Description: Linux Mint 19.3 Tricia
Release: 19.3
Codename: tricia
Re: Bug in Install additional devices for 2019.2
The Issue in my case was, I was logged in as a non-root user, So the installer did not have permissions to install in /opt. Instead of throwing a warning or error, It silently kept waiting on that screen.
Launching vivado as root and then installing the device worked.
Hello jvs@dyumnin.com ,
I believe i've seen something similar when a machine is low on the memory size.
I just want to check on this, in case that is the reason in your situation? How much memory is left on this machine?
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
